I've developed a TabStrip control, which has some special features like closeable tabs and drag'n'drop. It works nicely together with my ButtonControls, i. e. the ButtonControls appear transparently on the TabStrip, so you can finally use XP themes in your VB6 apps without having ugly drawing glitches.
As usual there're 2 builds: Unicode and ANSI. The setup contains both builds, corresponding help files and 3 sample projects for Visual Basic 6.0 and C++/WTL. The Unicode version is the preferred one, but doesn't run on Windows 98/Me. The ANSI version runs on Windows 98/Me and on Windows NT 4.0/2000/XP/2003.
If you think you've found a bug, you may ask me for a Debug build, which helps you to locate mem leaks and crashes caused by the control.
Please use the TabStrip forum for feedback.
[Screenshots] [Download] [Online help]
TabStrip 1.0.0
TabStrip 1.0.0
