ProgressBar 2.0.0
This forum contains the news and their comments from the old, phpBB2+ based version of the website.
Locked
ProgressBar 2.0.0
A new control has been completed: ProgressBar 2.0. It comes with full support for Windows Vista, i. e. the new progress bar features of Vista like progress states (Normal, Paused, Failed) are already supported.
As usual there're 2 builds: Unicode and ANSI. The setup contains both builds, corresponding help files and 2 sample projects for Visual Basic 6.0 and C++/WTL. The Unicode version is the preferred one, but doesn't run on Windows 98/Me. The ANSI version runs on Windows 98/Me and on Windows NT 4.0/2000/XP/2003/Vista.
If you think you've found a bug, you may ask me for a Debug build, which helps you to locate mem leaks and crashes caused by the control.
Please use the ProgressBar forum for feedback.
[Download] [Online help]
Locked
