Some time has passed since I've published a completely new control. So here's some new stuff: EditControls. This library contains a HotKeyBox, IPAddressBox, TextBox and UpDownTextBox control.
As usual there're 2 builds: Unicode and ANSI. The setup contains both builds, corresponding help files and 3 sample projects for Visual Basic 6.0 and C++/WTL. The Unicode version is the preferred one, but doesn't run on Windows 98/Me. The ANSI version runs on Windows 98/Me and on Windows NT 4.0/2000/XP/2003/Vista.
If you think you've found a bug, you may ask me for a Debug build, which helps you to locate mem leaks and crashes caused by the control.
Please use the EditControls forum for feedback.
[Screenshots] [Download] [Online help]
EditControls 1.0.0
EditControls 1.0.0
