Form Resize VB6
Captain
Form Resize VB6
Post by Mex »
Hallo Timo
Do you know, is it possible in VB6 somehow to "catch" forms resize_begin and resize_end events?
Re: Form Resize VB6
Subclassing the Form and handling WM_SIZING and WM_SIZE message should come close to this.
Captain
Re: Form Resize VB6
Post by Mex »
One more question :)
I have my own UniListview,all works fine. Now when i add manifest to my binary, resizing the listview is much slower.
Any idea what can cause this?
Re: Form Resize VB6
Without knowing what you do within the control when it is resized, it's difficult to tell.
Captain
Re: Form Resize VB6
Post by Mex »
This is very strange problem and happens only with Vista and Windows 7, but when i remove manifest file everything is ok.
With Windows XP works everything fine with manifest too.
If you have time i can send sourcecode and sample app, maybe you can find out what causes this problem?
Re: Form Resize VB6
Okay. But it might take some days as I'm short on time.
Captain
Re: Form Resize VB6
Post by Mex »
Ok here is small sample and my listviews sourcecode.
data is loaded from data.xml(saved recordset)
sample.zip
(118.32 KiB) Downloaded 4634 times
Re: Form Resize VB6
I'd say the performance hit is caused by the UserControl_Resize event handler which resizes all columns. Resizing a column causes all its content to be redrawn, so effectively all displayed cells are redrawn when resizing the control. Drawing text seems to be more expensive with themes enabled - I've already noticed this effect in one of my controls.
