Changing tab using code
The place for threads about TimoSoft TabStrip.
rlvision
Post by rlvision »
This is probably a stupid questions, but I've tried everything I can think of and nothing works. My question is very simple: How do you change the currently selected tab (programmatically)?
Re: Changing tab using code
Use the ActiveTab property, e. g.:
Set TabStrip1.ActiveTab = TabStrip1.Tabs(x)
rlvision
Post by rlvision »
Thanks a lot. Works like a charm!
