Hello Timo!
When i add columns and set the resizable = False, it does not work i can still change columns width.
Is this a bug or am i missing something? (Windows 7)
Alles gute;
Columns.Add and resizable
Re: Columns.Add and resizable
Ok its working nut not as i expected
Let's say i have 3 columns
First columns width is set to 0 and resizable to False.
2 other columns are lets say 200px.(see pics)
With mouse i can still change first columns width and now when its visible then its "locked".
BR;
BR;
Ok found a solution how to "lock" hidden column, but dont know if this is a right way
Private Sub theList_ResizingColumn(ByVal column As ExLVwLibUCtl.IListViewColumn, newColumnWidth As Long, abortResizing As Boolean)
If column.Width = 0 Then
newColumnWidth = 0
newColumnWidth = 0
This sounds like a bug of comctl32.dll, but I'll check (not today).
To comment your work-around: Why don't you set abortResizing to True?
I can confirm that this is a bug in comctl32.dll. You've already found the best work-around (except for the abortResizing thing).
I have a little problem dealing with columns, or rather headers. Once you drag one of the headers, its position changes, but the header index remains the same. Say, I've got three columns. When in normal order, Header indexed 0 is in Position 0, Header indexed 1 in Position 1, and Header indexed 2 in Position 2. If I drag Header indexed 1 into Position 0, it obviously retains the index 1, and changes its position from 1 to 0. Is it possible for the dragged header to change its index as well? I would like to iterate and print the the names of the headers in the order they are positioned, and not according to their indices, in a loop like:
This way, you'll get:
"Header Caption 0"
"Header Caption 1"
"Header Caption 2"
but I'd like to get:
"Header Caption 1" (dragged from position 1 to 0)
"Header Caption 0" (moved from position 0 to 1)
"Header Caption 2" (remained the same)
Pete
Dim a as Long
for a = 0 to lvw.columns.count -1
Print lvw.columns(a).caption
next
"Header Caption 0"
"Header Caption 1"
"Header Caption 2"
Pete
The index cannot be changed, but you can access the headers by position:
By the way, if you need this in order to persist the column order, you should think about using the Columns.PositionsString property instead.
Dim a as Long
Print lvw.columns(a, citPosition).caption
next
Oh, that was another simple, yet perfect solution. Thanks again.
Pete
Pete
