I' m trying to use an ANSI ComboBox control to choose and display greec, romanian and turkish text. I want to set the language codepage by changing the font.charset property (for example 161 for greec). But the items of combobox doesn't display correctly. For all other controls I tried this works fine - not for comboboxes.
If I choose one faulty entry of the comboboxes list by clicking it, the choosen text will be assignd to comboboxes.Text property and it shows correctly. Notice: Only the list content doesn't work.
By the way: The combobox controls from MS (standard and forms2) does display the list items incorrect too.
Any ideas?
Thx
Doublespin
How to change charset of ANSI ComboBox
Re: How to change charset of ANSI ComboBox
Why don't you use the Unicode ComboBox? It does not need this charset rubbish. ANSI is dead.
Because my App is an "old" one and it contains a lot of controls that doesn't support Unicode but working with charset property. And unfortunately there is no suitable alternative to replace the controls.
Okay, users could enter Unicode characters into the Unicode controls and your app could not handle these characters. This is the only problem I can see.
If you provide a small sample app that exhibits the problem, I'll do some tests tonight. Maybe the combo box simply does not update the drop-down list's font automatically. This could be worked around.
Hi TiKu
Thank you for your time.
To write Greek characters: In Control Panel, Regional and Language Options, Languages, Details add Greek Keyboard Layout
Choose the "EL Greek" keyboard and test it in Notepad. Type keys a, b, g on german or us keyboard will display the Greek chars Alpha, Beta, Gamma (αβγ)
Here ist my sampe.
On a form place one ANSI combobox and one textbox.
In Form_Load event paste the following:
Thx
Doublespin
Here ist my sampe.
Private Sub Form_Load()
Const GREEK_CHARSET = 161
ComboBox1.Style = sComboDropDownList
ComboBox1.UseSystemFont = False
ComboBox1.Font.Charset = GREEK_CHARSET
ComboBox1.ComboItems.RemoveAll
'Add the Greek chars Alpha, Beta, Gamma (Keys a, b, g on german keyboard)
ComboBox1.ComboItems.Add "áâã"
'Add the Greek chars Delta, Epsilon, Zeta (Keys d, e, y on german keyboard)
ComboBox1.ComboItems.Add "äåæ"
'Assign the chars Alpha, Beta, Gamma (Keys a, b, g on german keyboard)
ComboBox1.Text = "áâã"
'--> The text on combo will be OK
'--> The items list will not
'For control fill textbox
Text1.Font.Charset = GREEK_CHARSET
Text1.Text = "áâã"
'--> No Problem to display correct chars
Doublespin
Interesting: If I specify a manifest, so that Visual Styles are used, neither the text box nor the combo box display the characters correctly.
This seems to be an issue with Windows' native list box control. I don't know how to work around this bug.
