Controls doesn't work
I'm a novice programmer. I start learning using VB6. Which one should I put on my application, UTF or ANSI? I try both of them but nothing seems to work. All the controls don't work. Can anybody help me?
Re: Controls doesn't work
Could you please clarify what you mean with "doesn't work"?
The Unicode edition is the better choice.
