I know you are not developing this controls any more, but I found one very strange problem and maybe you have an idea why this is happening.
If you start Corel Draw when VB6 app, that is using your unicode controls, is running then all controls start showing control name instead of text property value aso. If you close Corel Draw, then everything is drawing/working just fine. Strangest problem ever...
