What is ButtonControls?
The place for threads about TimoSoft ButtonControls.
Locked
ButtonControls is a library containing four ActiveX controls that wrap the various flavors of the Button window class. The four controls (Frame, CommandButton, CheckBox, OptionButton) are 100% compatible to Windows XP which alone makes them better than VB6's built-in controls. ;) Furthermore the controls already support the new Windows Vista features like Command Links and Split Buttons.
The library is optimized for Visual Basic 6.0, but should also work in any other environment that supports COM controls.
[Download] [Online help] [Changelog] [Screenshots] [GitHub Repository]
Requirements: Windows XP/2003/Vista/2008/7/2008 R2/8/2012/8.1/2012 R2/10/2016.
Locked
