I've released ExplorerTreeView 1.11.0. Although the changelog is short, it's probably the release with the most extensive changes so far.
I've rewritten most internal stuff. Now the control needs less memory, is somewhat faster and doesn't lock folders anymore. And most important: I've fixed several crashes and many small memory leaks. AutoUpdate is working better, too.
However, there's also a disadvantage: The control doesn't run anymore on Windows NT 4.0 and Windows 95. If you really really need support for those two systems, let me know and I'll see what I can do to make it work again.
BTW, the samples (especially the CustomIcons sample) got updated, too.
[Download] [Samples] [Changelog]
