How can I retrieve / set the current position of the cursor in the textbox (as with .selstart)?
Thanks,
Bjoern
Position of the cursor
Re: Position of the cursor
Have a look at the GetSelection() method.
bjoernlueders
Thank you for the fast response.
I'm stuck here. How do i identify the Position of the "selectionStart"?
Dim selStart As Long
TextBox1.GetSelection selStart
' now selStart holds the cursor's position
bjoernlueders
Thank you very much.
One last question: How can i set the Position afterwards to "selstart+1"? .setselection(selstart,selstart+1)?
If you just want to change the cursor's position to one character ahead, use
If you want to select the first character after the cursor's position, use
SetSelection selStart + 1, selStart + 1Code: Select all
SetSelection selStart, selStart + 1Crunching for Fab36_Folding-Division at Folding@Home. Join Fab36/Fab30! - Folding@Home and BOINC
bjoernlueders
Thank you very much!
Everything is working just fine!
