Is there a way to get your ProgressBar into a StatusBar-Panel?
Thanx,
Bjoern
ProgressBar in StatusBar
Re: ProgressBar in StatusBar
have a look at the Embedded ProgressBar sample that comes with the StatusBar setup. It uses the Microsoft ProgressBar, but should be easy to change to use my ProgressBar. Let me know if you can't get it working, I'll provide a sample then.
bjoernlueders
Yep, it's working just fine!
Thank you very much for your excellent work and the quick help!
