Natorion
Posts: 14 Joined: 12 Jan 2009, 10:35
Post
by Natorion » 15 Jul 2009, 13:03
if I set ReadOnly=true the EditBox gets a grey background. I want to have the background have another colour. Using:
EditBoxControlInstance.BackColor = &HFF0000
has absolutly no effect. How do I alter the background?
Posts: 832 Joined: 28 Sep 2004, 21:10
Post
by TiKu » 15 Jul 2009, 15:41
You would need subclassing to change this color.
How urgent do you need a solution? I'm in the progress of updating some parts of EditControls and could implement a new property called "DisabledBackColor" or something like that. The problem is, that I do not have much time to work on the controls, so 2 weeks could pass before I can release the update.
Crunching for Fab36_Folding-Division at Folding@Home. Join Fab36/Fab30 ! - Folding@Home and BOINC
Natorion
Post
by Natorion » 16 Jul 2009, 07:08
Thank you, two weeks are enough for me
What exactly do you mean with subclassing in this context?
Post
by TiKu » 16 Jul 2009, 08:16
Natorion wrote: What exactly do you mean with subclassing in this context?
The WM_CTLCOLORSTATIC message that is sent to the control's parent window must be handled.
Natorion
Post
by Natorion » 16 Jul 2009, 11:44
I now tried to intercept the which fires when the text is changed so I can nullify the change. Unfortunatly there is no such event :/
Post
by TiKu » 16 Jul 2009, 15:57
Sounds like you're looking for the TextChanged event.
Natorion
Post
by Natorion » 21 Jul 2009, 08:28
Unfortanatly TextChanged fires after the change and with no parameters. I have done a workaraound now, wrapping the whole text changing
itmg
Posts: 13 Joined: 14 Jul 2009, 12:04
Post
by itmg » 25 Sep 2009, 14:00
what I'm doing wrong?
The backcolor of the text should be red also!
(55.99 KiB) Not downloaded yet
ButtonControls 1.4 Unicode
EditControls 1.4 Unicode
DateTimeControls 1.1 Unicode
Statusbar 1.2 Unicode
Post
by TiKu » 25 Sep 2009, 15:06
Looks like version 1.4.0 introduced several drawing issues. Please try the attached version.
Release - Unicode.zip
EditControls 1.4.1 pre-release (293.52 KiB) Downloaded 4099 times
itmg
Post
by itmg » 25 Sep 2009, 15:27
Thanks!
That was quick!
