Backcolor/ForeColor
The place for threads about TimoSoft ButtonControls.
itmg
Backcolor/ForeColor
Post by itmg »
the properties backcolor and forecolor don't work. You can change them, but the default value will be used always.
This applies to all the controls in the Library BtnCtrlLib
regards
andreas
ButtonControls 1.4 Unicode
EditControls 1.4 Unicode
DateTimeControls 1.1 Unicode
Statusbar 1.2 Unicode
Re: Backcolor/ForeColor
Well, sometimes the docs are helpful. ;)
http://www.timosoft-software.de/onlineh ... 20347895d8
This property affects owner-drawn buttons only.
This property isn't supported for themed checkboxes.
This property isn't supported for themed option buttons.
This property isn't supported for themed frames.
