Hi Timo
Is it possible to change balloontooltip on Texbox, when property Accept numbers only is set?
"Unaccetable character"... i want change this text to Estonian for exmaple?
BR;
						Balloon Tooltip
Re: Balloon Tooltip
This tooltip comes from Windows, so I'm afraid there's no direct way. But the following might work:
							- Subclass the TextBox.
- Watch out for the TTN_SHOW notification, which is sent via a WM_NOTIFY message.
- The lParam parameter sent with the notification points to a NMHDR struct, which should contain the tooltip's window handle in its hwndFrom member. Use the TTM_SETTITLE and TTM_UPDATETIPTEXT messages on this window to change the title and text displayed in the tooltip.
