TextBox-Control doesn't fire "Validate" event
If I change focus between several TextBox controls and the "CausesValidation" property of each control is set to true, the "Validate" event should be fired. But this is only the case, when the focus is changed by pressing the tab key and not if I activate another control by mouse click
						Re: TextBox-Control doesn't fire "Validate" event
I can reproduce this behavior and will try to fix it. But this probably won't happen within the next 2 weeks, because I have much to do and next week I will be on vacation.
Looks like this problem: http://support.microsoft.com/?scid=kb%3 ... 26&x=7&y=8
Okay, I've fixed it for the TextBox control. I still need to check the other controls, especially IPAddressBox and UpDownTextBox might be more complicated.
If you need this fix urgently, I can send you a prerelease.
thanks a lot for the quick response!
If you plan an official release within the next 2-3 weeks then there is no need for a pre-release. Otherwise it would be fine
Cheers
Michael
 Cheers
Michael
Version 1.5.0 has been released. It contains the fix.
