I'm trying ExplorerListview (latest version) and found that it crashes when I try to save projects. I can open and save your sample projects, but if I add a new Listview to the form, or start a new project and put a single listview on the form, and then try to save it, the whole VB6 IDE crashes (and trashes the form file)! VB6 produces .tmp files where you can see where it crashed. Exactly where seems different depending on project though. Tell me if you need some more info from me.
Crash bug when saving projects
Re: Crash bug when saving projects
I'll look into it tonight.
Which version of Windows do you use? So far I cannot reproduce the crash. Oh, and probably more important: Do you change any properties before saving the project? Which?
I run Windows XP SP2
All I do is to create a new project, add ExplorerListView to the component list and draw a listview onto the form, and then save the form.
The crash dialog says something about oleaut32.dll:
AppName: vb6.exe AppVer: 6.0.97.82 ModName: oleaut32.dll
ModVer: 5.1.2600.3139 Offset: 0000503fRe: Crash bug when saving projects
I could reproduce it in a Virtual Machine with Windows XP and I could fix it. Windows 7 (maybe also Vista) seems to have some extra error checks when dealing with safe arrays, so it does not crash.
Some of my other controls probably have the same problem.
I have another XP computer at work that I did the same test on, and same result. This machine is XP SP3 with all updates.I could reproduce it in a Virtual Machine with Windows XP and I could fix it. Windows 7 (maybe also Vista) seems to have some extra error checks when dealing with safe arrays, so it does not crash.
I did a quick test with all your other controls, and I'm glad to let you know that I had no problems with them!TiKu wrote:Some of my other controls probably have the same problem.
Many thanks for testing. It must have taken a while. I'm glad that none of my other controls crashes, but just to be sure, I integrated the fix into all of them that contain the same errornous code.
By looking at the unfinished saved files it was pretty clear that the crash happened when saving the properties of the control. Since the listviews in your projects were working, I figured that if I compared them to new ones and change the new ones' settings to match "your", I should be able to determine the cause. It worked!
The crash occurs when you do not enter anything in the EmptyMarkupText
