I start a new Project (Win XP, VB6), add the component TimoSoft ExplorerListView 1.0 Unicode and place a ListView to the frame.
When I save the Project, VB6 chrashes down. So I can not send you an example project. but you can test ist by yourself. Just start a new project, place the object and boom.
Any idea?
Project error
Re: Project error
This sounds like the problem described by rlvision a few days ago: viewtopic.php?f=28&t=499
Do you use the version that I have released on November 7th?
Rucksacktraeger
- Lieutenant
Resolved
what I did before was to check on your website if you have a newer version. I found out that version 1.0.0 is still the newest version. So i didn't download again because I already had version 1.0.0. Sorry, I didn't see that post .
But by downloading and installing it again btw. the version from November 7th, it works now.
Thanks!
Thanks!
Re: Project error
The version you had was a Release Candidate.
