error ole drag and drop in textbox.
codigo of button:
Private Sub TextBox1_OLEDragDrop(ByVal data As EditCtlsLibUCtl.IOLEDataObject, effect As EditCtlsLibUCtl.OLEDropEffectConstants, ByVal button As Integer, ByVal shift As Integer, ByVal x As Single, ByVal y As Single)
If data.GetFormat(1) Then
TextBox1.Text = data.GetData(1, -1, 1)
ElseIf data.GetFormat(15) Then
please help
string of test:
[HD 1080p] SNSD 少女時代 소녀시대
see video attach for details
Test error over windows xp pro with service pack 3.
supersecretos
- error edit control.zip
- video error (uncompress)
- (568.36 KiB) Downloaded 728 times
Re: error ole drag and drop in textbox
you're using format 1, which is vbCFText which is ANSI text. Try format 13, which is Unicode text.
supersecretos
help data.Files.Item (1)
Thank you very much for the help.
another little thing, could you give me a link or website where this explained these values, because the help of control (chm) not detailed stuff, such as:
the values for "FormatID" in method "data.GetData".
Other help. Now as I get the files. Previously "control non-unicode" used "data.Files.Item (1)" in the event oledraganddrop, but now with unicode controls it generates error.
Thanks in advance.
Thanks in advance.
You won't find a list of all possible formats. There are some standard formats like those defined by VB (vbCF* constants) and the Windows SDK (CF_* constants). I believe the CF_* constants are documented somewhere on MSDN. Additionally any format, that has been registered by a call to RegisterClipboardFormat API, can be used.
Of course not all formats are available in each situation.
supersecretos
Ok.
