Listview items colors
Hi TiKu.
I'm still familiarizing myself with the code of your Listview control. This time, I'd like to change the backcolor of some Listview items. I've looked into the code of your Customdraw Listview example, but couldn't find any method that would be responsible for changing the backcolor of an item in a row, and in a column. Could you direct me into a solution to achieve that? I'd much appreciate it.
Cheers,
Pete
Cheers,
Pete
Re: Listview items colors
It's simple. You've probably seen in the Fonts & Color sample that it sets the TextBackColor. Well, replace TextBackColor with TextColor. TextColor and TextBackColor are ByRef parameters of the CustomDraw event.
This will set each item to red text:
This will set only the 3rd item to red text:
This will set the 1st column of each item to red text:
This will set the 2nd column of the 3rd item to red text:
Select Case drawStage
Case CustomDrawStageConstants.cdsPrePaint
furtherProcessing = CustomDrawReturnValuesConstants.cdrvNotifyItemDraw
Case CustomDrawStageConstants.cdsItemPrePaint
TextColor = RGB(255, 0, 0)
furtherProcessing = CustomDrawReturnValuesConstants.cdrvNewFont
End SelectCode: Select all
If listItem.Index = 2 Then
TextColor = vbRed
furtherProcessing = CustomDrawReturnValuesConstants.cdrvNotifySubItemDraw
Case CustomDrawStageConstants.cdsSubItemPrePaint
If listSubItem.Index = 0 Then
TextColor = vbRed
TextColor = ExLvw.ForeColor
If listSubItem.Index = 1 Then
TextColor = vbRed
End SelectTiKu
Dear me. You were right. It's really simple. I just seem to have missed that event.
Thanks again.
Thanks again.
Yes, that was straighforward indeed.
However, I'd like to get a similar result if I, say, click on a listview item and the item's backcolor changes into a different color. That's a tricky one, to be honest.
You want the TextBackColor of a selected item to be another color than the default blue?
Yes, something like that, and also maybe in cases when I want to select more than one item, not necessarily through the mouse click, but maybe through a bit of code from a CommandButton.
As far as I know the native list view control of Windows, which my control is based on, does not allow a custom selection background color. Of course you could use the CustomDraw event to draw the entire item yourself if it is selected. But if you want it to look the same, just with a different background color, it will be a lot of work.
What a shame.
However, learning that your Listview control was based on the Windows Listview control got me thinking straightaway. I remembered using a module to subclass a Listview so that the user could easily change the backcolor of an item through a function. I implemented that module and used the function and voila, I've got a solution!
Please find attached the file.
Cheers,
Pete
PS
The code is nothing to do with an item being selected, though.
Cheers,
Pete
PS
- ExLvwDragDrop.zip
- (155.69 KiB) Downloaded 2145 times
If you look carefully at the Fonts & Colors sample that comes with ExplorerListView, you'll notice that the rows have alternating background colors. The sample does this by setting the TextBackColor parameter of the CustomDraw event. Behind the scenes your module and my control do the same thing.
That's right. Two different methods of doing the same thing.
But, as I did in my sample project, I wanted to change the color when the user presses the button. I couldn't do the same with your code in the Customdraw event. In my case, the function does the trick. In the case of your coding, all you can do to change the color seems to be only possible in that Customdraw event, and not through a function, declared in the Button Click event.
Pete
Pete
