Balloon Tooltip
Captain
Balloon Tooltip
Post by Mex »
Hi Timo!
Do you know any good solution?
MDI application with child forms. When child form is minimized and mouse is moved over forms titlebar then balloon tooltip pops out?
Best regards;
Captain
Re: Balloon Tooltip
Post by Mex »
OK I found one solution, but if you know any good solution, please post! :)
Re: Balloon Tooltip
You want to display a tool tip for minimized MDI child windows?
I don't know of any "official" way to do this, but my approach would be to create a tool tip and add the window as a tool when it gets minimized and remove/detach it when it gets restored.
Captain
Re: Balloon Tooltip
Post by Mex »
TiKu wrote:You want to display a tool tip for minimized MDI child windows?
Yep, thats what I did and works fine!
Re: Balloon Tooltip
Good to know that this is a working approach.
By the way, many thanks for the donation. I appreciate it. :)
