Small non-critical bug: When the default text value of a WindowlessLabel is blank and AutoSize is set to True, the control crashes VB when opening it inside the IDE.
[Edit] It looks like Autosize crashes the form even when there is a Text value in the label. It crashes when the form loads in the IDE even on a new Label I just added. So it looks like AutoSize is broken.
Autosize bug
Re: Autosize bug
Thanks for reporting this bug. I wonder how this could slip through as it seems to have been like this all the time.
Well, I've fixed it and also applied the patches that reduce GDI resource usage.
www.timosoft-software.de/stuff/lblctls10467-rel.zip
www.timosoft-software.de/stuff/LblCtls10467-Release.exe
