I know you removed the databinding functionality, but is it possible to restore the DataField property (CheckBox,TextBox), just for simple get;set using?
Best Regards
DataField
Re: DataField
I think I've found a way to provide data-binding again. I'll do more tests before providing new releases.
Thanks for the donation btw.
Re: DataField
Hi Meelis,
In case you're interested, here's a first pre-release of the LabelControls library with reactivated data-binding:
www.timosoft-software.de/stuff/lblctls10572-rel.zip
www.timosoft-software.de/stuff/LblCtls10572-Release.exe
Re: DataField
Thnx, but where I really need DataField property is CheckBox control.
I have my own cotnrol what handles all databinding and communication and datafield property is really important.
Currently i'm using for workaround a Tag property, but in some cases I need Tag property for other values
Re: DataField
I've released version 1.8.9. Welcome back data-binding.
