Mouse Pointer Bugs
The place for threads about TimoSoft LabelControls.
baron
Mouse Pointer Bugs
Post by baron »
Two bugs with the label and mouse pointers... I attached an example but they are very simple:
- Setting a mousepointer only works within a certain pixel range and has no effect anywhere else on the label (second label has an hourglass set)
- Setting a mousepointer on a control NEXT to the label and moving the mouse from that control to the label makes that label have the same mousepointer as its neighbour (move your mouse from the button (cross pointer) slowly down to the first label which has no mousepointer set).
MousePointerBug.zip
Bugs
(1.89 KiB) Downloaded 3812 times
Re: Mouse Pointer Bugs
This one was relatively easy to fix.
Seems like I've implemented mouse events after the MousePointer property and never tested the MousePointer property again - at least the mouse events have broken this property.
