Resource Leak
The place for threads about TimoSoft LabelControls.
baron
Resource Leak
Post by baron »
Hello again,
When setting the MouseIcon, the label control doesn't release the GDI/User resources after it closes. The fact that it takes up a bunch of resources is not the main issue (although fewer resources would be nice too) - it's that it doesn't release them.
Attached is a simple sample. Click on the button to open a new window, and then close it again while watching the User/GDI.
MousePointerBug.zip
Bug Sample
(5.65 KiB) Downloaded 6814 times
Re: Resource Leak
thanks for reporting. I think I've found and fixed the problem, hopefully without introducing new problems.
www.timosoft-software.de/stuff/lblctls10677-rel.zip
www.timosoft-software.de/stuff/LblCtls10677-Release.exe
baron
Re: Resource Leak
Post by baron »
Thank you again!
Looks great so far on tests, doesn't even take resources on load.
