I'm afraid you didn't find a bug.
I think you missed that the hit-test codes are not mutually exclusive, but can be combined.
&H4000040 is the result of (&H4000000 Or &H40). &H4000000 is htContent, and &H40 is htItemStateImage. So the hit point lies within the item's content as well as within the item's state image - and this is where you clicked. The flag htContent is new for Windows Vista and up. Microsoft has defined the state image to be part of the item's content.
&H4000004 is the result of (&H4000000 Or &H4). &H4 is htItemLabel. So the hit point lies within the item's content as well as within the item's label - and this is where you clicked.
I suppose with 70 you mean htItem (&H46)? Well, this one is the combination (binary Or) of htItemIcon, htItemLabel, and htItemStateImage (&H2 Or &H4 Or &H40). You can use htItem if you're not interested in the exact part of an item that has been hit. So instead of:
Dim bHitItem As Boolean
bHitItem = False
If hitTestDetails And htItemIcon Then
bHitItem = True
ElseIf hitTestDetails And htItemLabel Then
bHitItem = True
ElseIf hitTestDetails And htItemStateImage Then
bHitItem = True
If bHitItem Then ...
you can just write:
bHitItem = False
If hitTestDetails And htItem Then
bHitItem = True
This would also work (but is not as easy to read):
bHitItem = False
If hitTestDetails And (htItemIcon Or htItemLabel Or htItemStateImage) Then
bHitItem = True
