Hello!
In Microsoft Word, a line break is defined by Chrw(13).
In order to show a line break in your textbox control, it's however necessary to have Chrw(13) + Chrw(10).
Else, no linebreak will be displayed.
I imagined I should play around with "SoftLineBreak" in order to provoke / show a linebreak at Chrw(13) only, but that wouldn't help.
Can anybody tell me how I could make it so that Chrw(13) is shown as a line break?
I wouldn't want to alter the text (for example by replacing Chrw(13) with Chrw(13) + Chrw(10)), as I don't think this would be the correct way to handle this.
Thank you for the help!
Linebreak in TextBox
Re: Linebreak in TextBox
Which version of Word do you use?
I can test only with Word 2010. I open Word, write "Line 1", press Enter, write "Line 2". Then I select all text, press Ctrl+C, go to a VB6 form with my Unicode TextBox on it (with the default properties, only Multiline set to True), set the focus to this text box and press Ctrl+V. It displays "Line 1" and "Line 2" on separate lines, just as expected.
Am I missing anything?
Yes, you're missing something.
I'm using Word 2007.
I'm using the following code to get the text:
If you get the text this way, the line break is represented by Chrw(13) only, not by vbCrLf.
Private Function GetText(ByVal uFile As String) As String
Dim nWord As Object ' Word.Application
Set nWord = CreateObject("Word.Application")
'set some settings/properties
With nWord
.Visible = False
.DisplayAlerts = 0 'wdAlertsNone
End With
'open the document
Dim nDoc As Object 'Word.document
Set nDoc = nWord.Documents.Open(uFile)
If nDoc Is Nothing Then
Debug.Assert False
'unable to get the document contents
'handle this condition here...
'read the contents from the Doc object
GetText = nDoc.Content
nDoc.Close
Set nDoc = Nothing
nWord.Quit False
Set nWord = Nothing
End FunctionRe: Linebreak in TextBox
I thought that "InsertSoftLinebreaks" would achieve what I want, but obviously not.
I can replace Chrw(13) with vbNewLine of course, but I thought that you would perhaps handle this case.
Ok, I see. I cannot find a better solution other than parse the text and replace any vbCr. I could implement this in the control, but why? I would do the same as you currently already do in VB6. Unfortunately the Windows Edit control API does not seem to have any built-in feature that we could use here.
Thank you! Yes, I totally agree.
I have checked the .NET textbox control, and it behaves just like that as well.
Maybe I have found something. Starting with Windows 10 1809 it seems to be possible to configure the native edit control in a way that allows a single CR or a single LF for line breaks.
