Repaint with tooltips fails
The place for threads about version 2.x of TimoSoft ExplorerTreeView.
c.haarmeijer
Post by c.haarmeijer »
I've enabled tooltips in the treecontrol, but repainting fails then. It often shows the gray background where the treecontrol should be. I've attached a screenshot (look at the gray rectangle) and the settings I used. Treecontrol version is: 2.0.0.187 Beta4 (ANSI). I am running Windows XPSP2 (themed).
We are evaluating your tree control to find out if it is suitable for use in our Lumo Builder software product that will be launched early next year.
Kind regards,
Chris Haarmeijer
bugreport_attachement.zip
(29.65 KiB) Downloaded 3887 times
please try the attached build 196. I've done relative large changes since Beta 4 and some of those changes affect drawing, so maybe the problem is already gone.
ExTVwA200196.zip
ExplorerTreeView 2.0.0 Beta 4+ (Build 196)
(240.66 KiB) Downloaded 3875 times
Guest
Post by Guest »
Dear Tiku,
Thank you for the quick response. I've tried your new build but I has no success. The problem is still there.
Kind regards,
Chris
I'm investigating this problem, but so far I was not able to reproduce it. Would it be possible to create a small sample project demonstrating the bug? It would be very helpful.
/edit: You may also try setting the Composited property to False as this property is somewhat problematic and shouldn't be used if not necessary. I've changed the control's behavior to default to Composited = False for that reason.
If it's still of interest: I think I've fixed the problem (although I never was able to reproduce it). Please try the attached build.
ExTVwA200200.zip
ExplorerTreeView 2.0.0 Beta 4+ (Build 200)
(241.35 KiB) Downloaded 3887 times
Guest
Post by Guest »
The problem seems to be gone for now. Sorry for the late response, I got no confirmation e-mail from PHPbb that there was a reply (or it went straight into my junkmail). Thanks for the help!
Chris
